[Qgis-developer] little fix in tip
Werner Macho
werner.macho at gmail.com
Tue Jun 18 03:32:12 PDT 2013
Hi Richard!
Thanks for that tip .. I changed it ..
regards
Werner
On Tue, Jun 18, 2013 at 12:14 PM, Richard Duivenvoorde
<rdmailings at duif.net>wrote:
> During translation I came along this tip:
> QGIS has plugins that extend its functionality. QGIS ships with some core
> plugins you can explore from the Plugins->Manage Plugins menu. In addition
> there are over 150 Python plugins contributed by the user community that
> can be installed from the Plugins->Fetch Python Plugins menu. Don't miss
> out on all QGIS has to offer---check out the plugins and see what they can
> do for you.
> The name of the menu-item changed, so I think I should be something like:
> plugins you can explore and activate from the Plugins->Manage and Install
> Plugins menu. In addition there are over 150 Python plugins contributed by
> the user community that can be installed via this same menu. Don't miss out
> on all QGIS has to offer---check out the plugins and see what they can do
> for you.
> I fear a pull request would not make it, so maybe someone with direct
> commit rights change this (and or the text)?
> Regards,
> Richard
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130618/942d7676/attachment-0001.html>
