[Qgis-developer] [Clipping] VRT memory
Alexia Mondot alexia.mondot at c-s.fr
Tue Jun 18 05:43:29 PDT 2013
Hello,
Recently, I had a problem while clipping a non georeferenced image based
on (0,0), x right, y down, because of the negative coordinates.
On the clipping tool, a tip consists in removing the minus of the
coordinates in the expression of the command gdal_translate to run.
It works fine with a vrt written on disk.
When I try to clip a vrt memory, the clipping tool writes all the vrt in
the expression of the command to run (that is ok).
When I run the clipping, I get this :
> Warning 1: Line 0: Attribute value should be single or double quoted.
> Going on, but this is invalid XML that might be rejected in future
> versions.
> ERROR 1: Line 0: Didn't find expected '=' for value of attribute '\'.
> GDALOpen failed - 1
But here's the thing, it works fine from a terminal.
In the clipping tool, when I change all protected double quotes \", to
simple quotes ', the clipping works fine.
It seems to be an anomaly of the clipping tool.
Thanks in advance,
Alexia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130618/90ada3f4/attachment.html>
