I have qgis 1.8 and 1.9 from the kyngchaos server and I've tried to install
the nightly build from http://qgis.dakotacarto.com/ for testing.
Unfortunately, after running the dmg I get the following error upon
starting qgis2.0_dev.app.
Any help appreciated,
Thanks
Agus
Process: QGIS_2.0-dev [1500]
Path: /Volumes/VOLUME/QGIS_2.0-dev.app/Contents/MacOS/QGIS_2.0-dev
Identifier: org.qgis.qgis-dev
Version: 1.9.0 (1.9.0 [c1f8230])
Code Type: X86-64 (Native)
Parent Process: launchd [696]
Date/Time: 2013-06-26 06:51:16.512 +0200
OS Version: Mac OS X 10.7.5 (11G63b)
Report Version: 9
Interval Since Last Report: 471662 sec
Crashes Since Last Report: 13
Per-App Crashes Since Last Report: 2
Anonymous UUID: 2003F4F5-1D34-4414-BB2C-941F6908FE81
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
Referenced from: /Volumes/VOLUME/QGIS_2.0-dev.app/Contents/MacOS/QGIS_2.0-dev
Reason: image not found
Binary Images:
0x10da6c000 - 0x10e158ff7 +org.qgis.qgis-dev (1.9.0 -
1.9.0 [c1f8230]) <AAA245A9-A8DC-3690-8234-2DD676DA95FE>
0x10e3af000 - 0x10e456fff +libqwt.dylib (6.0.2 -
compatibility 6.0.0) <4F5B28B2-7A1A-3F70-A676-540B3120CB65>
/Volumes/VOLUME/QGIS_2.0-dev.app/Contents/MacOS/lib/libqwt.dylib
0x10e4a5000 - 0x10e4dcff7 +QtSql (4.8.4 - compatibility
4.8.0) <09637D90-7186-82BA-F09C-ECB3744217FF>
/Volumes/VOLUME/QGIS_2.0-dev.app/Contents/Frameworks/QtSql.framework/Versions/4/QtSql
0x10e4f4000 - 0x10fb46ff7 +QtWebKit (4.9.3 -
compatibility 4.9.0) <6F06A446-57FA-621E-CBF7-7C4EAE419FCB>
/Volumes/VOLUME/QGIS_2.0-dev.app/Contents/Frameworks/QtWebKit.framework/Versions/4/QtWebKit
0x7fff6d66c000 - 0x7fff6d6a0baf dyld (195.6 - ???)
<0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
Model: MacBookAir4,1, BootROM MBA41.0077.B0F, 2 processors, Intel Core
i5, 1.6 GHz, 4 GB, SMC 1.74f4
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE,
0x4D34373142353737334448302D4348392020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE,
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xE9),
Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD TS128C, 121.33 GB
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 3
USB Device: Optical Mouse, 0x0458 (KYE Systems Corp.), 0x003a, 0xfa130000 / 6
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id,
0x024a, 0xfa120000 / 5
USB Device: BRCM20702 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821f,
0xfa113000 / 7
USB Device: FaceTime Camera (Built-in), apple_vendor_id, 0x850a, 0xfa200000 / 2
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: eGo USB, 0x059b (Iomega Corporation), 0x0070, 0xfd110000 / 3
