[Qgis-developer] Dev plugin for master
Marco Bernasocchi marco at bernawebdesign.ch
Wed Jun 26 05:26:46 PDT 2013
mmmm IIRC 2.0 was mentioned to be hardcoded temporarily in plugin manager
by Boris. I definitely have a plugin with minVersion=2.0
the warning is different as well IIRC. maybe something else? like sipV1 vs
sip v2? (speculation)
Marco Bernasocchi (mobile)
http://opengis.ch
On Jun 26, 2013 2:19 PM, "Werner Macho" <werner.macho at gmail.com> wrote:
> There is no 2.0 version right now ..
> IIRC minimum version right now (to be able to use it in master) should be
> 1.9)
> hope this solves your problem
> kind regards
> Werner
> On Wed, Jun 26, 2013 at 2:01 PM, PIERRE Sylvain <sylvain.pierre at cg67.fr>wrote:
>> Hi,****
>> I’m trying to develop a small plugin for master.****
>> I have set qgisMinimumVersion to 2.0 and stored the plugin in
>> .qgis2\python\plugins but running  Qgis does :****
>> *This plugin is incompatible with this version of QGIS*
>> Plugin designed for QGIS 1.x****
>> *ThemeManager*****
>> Installed version: ? (in
>> C:/Users/sylvain.pierre/.qgis2/python/plugins/ThemeManager)****
>> What should be the solution?****
>> Thanks****
>> *→*  *Sylvain PIERRE*
>>          Ingénieur Géographe****
>>          Adjoint au chef du service****
>>          Direction de l’Agriculture, de l’Espace Rural et de
>> l’Environnement****
>>          Service Administration Générale****
>>        *Conseil Général du Bas-Rhin*
>> [image: Description : Description :
>> \\dsi7085103\c$\Users\samuel.guigon\Pictures\CG67\logo_CG67+www_coul.jpg]<http://www.bas-rhin.fr/>
>>          Passerelle 67
>>          20 rue Livio / 67000 Strasbourg
>>          Tél : +33 3 88 76 68 88 – mobile :
>>          Fax : 03 88 76 68 71
>>          Email : sylvain.pierre at cg67.fr****
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130626/20cecc14/attachment-0001.html>
