[Qgis-developer] Dev plugin for master
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Jun 26 05:30:29 PDT 2013
You are correct, you need to set qgisMinimumVersion to 2.0
How old is your master version?
Things have changed quickly last weeks...
On 06/26/2013 02:26 PM, Marco Bernasocchi wrote:
> mmmm IIRC 2.0 was mentioned to be hardcoded temporarily in plugin
> manager by Boris. I definitely have a plugin with minVersion=2.0
> the warning is different as well IIRC. maybe something else? like
> sipV1 vs sip v2? (speculation)
> Marco Bernasocchi (mobile)
> http://opengis.ch
> On Jun 26, 2013 2:19 PM, "Werner Macho" <werner.macho at gmail.com
> <mailto:werner.macho at gmail.com>> wrote:
> There is no 2.0 version right now ..
> IIRC minimum version right now (to be able to use it in master)
> should be 1.9)
> hope this solves your problem
> kind regards
> Werner
> On Wed, Jun 26, 2013 at 2:01 PM, PIERRE Sylvain
> <sylvain.pierre at cg67.fr <mailto:sylvain.pierre at cg67.fr>> wrote:
> Hi,
> I'm trying to develop a small plugin for master.
> I have set qgisMinimumVersion to 2.0 and stored the plugin in
> .qgis2\python\plugins but running Qgis does :
> *This plugin is incompatible with this version of QGIS*
> Plugin designed for QGIS 1.x
> *ThemeManager*
> Installed version: ? (in
> C:/Users/sylvain.pierre/.qgis2/python/plugins/ThemeManager)
> What should be the solution?
> Thanks
> *?**Sylvain PIERRE*
> Ingénieur Géographe
> Adjoint au chef du service
> Direction de l'Agriculture, de l'Espace Rural et de
> l'Environnement
> Service Administration Générale
> *Conseil Général du Bas-Rhin*
> Description : Description :
> <http://www.bas-rhin.fr/>
> Passerelle 67
> 20 rue Livio / 67000 Strasbourg
> Tél : +33 3 88 76 68 88
> <tel:%2B33%203%2088%2076%2068%2088> -- mobile :
> Fax : 03 88 76 68 71 <tel:03%2088%2076%2068%2071>
> Email : sylvain.pierre at cg67.fr
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130626/07a5b2de/attachment.html>
