[Qgis-developer] Dev plugin for master
Andreas Neumann
a.neumann at carto.net
Wed Jun 26 05:29:17 PDT 2013
But version 2.0 is hard-coded now in master. So Pierre should use 2.0
now.
Pierre - did you create the metadata.txt file? This file is required
for QGIS 2.0. See section metadata.txt at
http://www.qgis.org/pyqgis-cookbook/plugins.html
Andreas
On Wed, 26 Jun 2013 14:19:03 +0200, Werner Macho wrote:
> There is no 2.0 version right now ..
> IIRC minimum version right now (to be able to use it in master)
> should
> be 1.9)
> hope this solves your problem
> kind regards
> Werner
> On Wed, Jun 26, 2013 at 2:01 PM, PIERRE Sylvain wrote:
>> Hi,
>> I’m trying to develop a small plugin for master.
>> I have set qgisMinimumVersion to 2.0 and stored the plugin in
>> .qgis2pythonplugins but running Qgis does :
>> THIS PLUGIN IS INCOMPATIBLE WITH THIS VERSION OF QGIS
>> Plugin designed for QGIS 1.x
>> THEMEMANAGER
>> Installed version: ? (in
>> C:/Users/sylvain.pierre/.qgis2/python/plugins/ThemeManager)
>> What should be the solution?
>> Thanks
>> → SYLVAIN PIERRE
>> Ingénieur Géographe
>> Adjoint au chef du service
>> Direction de l’Agriculture, de l’Espace Rural
>> et de l’Environnement
>> Service Administration Générale
>> CONSEIL GÉNÉRAL DU BAS-RHIN
>> [1]
>> Passerelle 67
>> 20 rue Livio / 67000 Strasbourg
>> Tél : +33 3 88 76 68 88 [2] – mobile :
>> Fax : 03 88 76 68 71 [3]
>> Email : sylvain.pierre at cg67.fr [4]
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org [5]
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer [6]
> Links:
> [1] http://www.bas-rhin.fr/
> [2] http://webmail.carto.net/tel:%2B33%203%2088%2076%2068%2088
> [3] http://webmail.carto.net/tel:03%2088%2076%2068%2071
> [4] mailto:sylvain.pierre at cg67.fr
> [5] mailto:Qgis-developer at lists.osgeo.org
> [6] http://lists.osgeo.org/mailman/listinfo/qgis-developer
> [7] mailto:sylvain.pierre at cg67.fr
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
