[Qgis-developer] Dev plugin for master
PIERRE Sylvain sylvain.pierre at cg67.fr
Wed Jun 26 05:56:11 PDT 2013
Master version installed yesterday with osgeo4w apt
I don’t have metadata.txt file, only entries in _init_.py file…
→  Sylvain PIERRE
         Ingénieur Géographe
         Adjoint au chef du service
         Direction de l’Agriculture, de l’Espace Rural et de l’Environnement
         Service Administration Générale
       Conseil Général du Bas-Rhin
[cid:image001.jpg at 01CE727D.4C150ED0]<http://www.bas-rhin.fr/>
         Passerelle 67
         20 rue Livio / 67000 Strasbourg
         Tél : +33 3 88 76 68 88 – mobile :
         Fax : 03 88 76 68 71
         Email : sylvain.pierre at cg67.fr<mailto:sylvain.pierre at cg67.fr>
De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Denis Rouzaud
Envoyé : mercredi 26 juin 2013 14:30
À : Marco Bernasocchi
Cc : qgis-developer
Objet : Re: [Qgis-developer] Dev plugin for master
You are correct, you need to set qgisMinimumVersion to 2.0
How old is your master version?
Things have changed quickly last weeks...
On 06/26/2013 02:26 PM, Marco Bernasocchi wrote:
mmmm IIRC 2.0 was mentioned to be hardcoded temporarily in plugin manager by Boris. I definitely have a plugin with minVersion=2.0
the warning is different as well IIRC. maybe something else? like sipV1 vs sip v2? (speculation)
Marco Bernasocchi (mobile)
http://opengis.ch
On Jun 26, 2013 2:19 PM, "Werner Macho" <werner.macho at gmail.com<mailto:werner.macho at gmail.com>> wrote:
There is no 2.0 version right now ..
IIRC minimum version right now (to be able to use it in master) should be 1.9)
hope this solves your problem
kind regards
Werner
On Wed, Jun 26, 2013 at 2:01 PM, PIERRE Sylvain <sylvain.pierre at cg67.fr<mailto:sylvain.pierre at cg67.fr>> wrote:
I’m trying to develop a small plugin for master.
I have set qgisMinimumVersion to 2.0 and stored the plugin in .qgis2\python\plugins but running  Qgis does :
This plugin is incompatible with this version of QGIS
Plugin designed for QGIS 1.x
ThemeManager
Installed version: ? (in C:/Users/sylvain.pierre/.qgis2/python/plugins/ThemeManager)
What should be the solution?
Thanks
→  Sylvain PIERRE
         Ingénieur Géographe
         Passerelle 67
         Email : sylvain.pierre at cg67.fr<http://www.bas-rhin.fr/>
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer<http://www.bas-rhin.fr/>
_______________________________________________<http://www.bas-rhin.fr/>
Qgis-developer mailing list<http://www.bas-rhin.fr/>
Qgis-developer at lists.osgeo.org<http://www.bas-rhin.fr/>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130626/deedcb8a/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130626/deedcb8a/attachment-0001.jpg>
