[Qgis-developer] Deactivate raster icon generation by default
Matthias Kuhn matthias.kuhn at gmx.ch
Thu Jun 27 04:08:54 PDT 2013
On linux it's in ~/.config/QGIS/QGIS2.conf (I believe in every
distribution).
Default is still true. It's a really simple fix, I'll just commit it.
If there's a problem, please complain.
If there's the demand for it, a threshold size (resolution * bands?)
could be introduced (for 2.1 I'd say).
On Don 27 Jun 2013 11:38:22 CEST, Werner Macho wrote:
> ok .. then i am surprised why deleting the .qgis2 folder helped ..
> On Thu, Jun 27, 2013 at 11:36 AM, Nathan Woodrow <madmanwoo at gmail.com
> <mailto:madmanwoo at gmail.com>> wrote:
>     Werner,
>     That setting is not stored in the .qgis2 folder.  It will be where
>     ever the settings for QGIS are stored. In windows this in the
>     registry.
>     - Nathan
>     On Thu, Jun 27, 2013 at 7:31 PM, Werner Macho
>     <werner.macho at gmail.com <mailto:werner.macho at gmail.com>> wrote:
>         Hmm . I just tested and looked ..
>         It seems that it is already deactivated by default ..
>         deleting the .qgis2 folder and start from scratch showed that
>         it is not active ..
>         probably it's something from an earlier installation?
>         can anyone confirm?
>         On Thu, Jun 27, 2013 at 11:06 AM, Anita Graser
>         <anitagraser at gmx.at <mailto:anitagraser at gmx.at>> wrote:
>             +1 for "off" by default.
>             On Thu, Jun 27, 2013 at 9:54 AM, Andreas Neumann
>             <a.neumann at carto.net <mailto:a.neumann at carto.net>> wrote:
>                 Hi,
>                 A discussion on the german fossgis-user group revealed
>                 that generating raster previews slows down raster
>                 loading a lot. Esp. for VRT raster catalogs.
>                 Can we set this setting (Settings -> Options -> Canvas
>                 and Legend -> Create Raster Icons (may be slow)) to
>                 off by default for new users?
>                 I think performance is much more important than raster
>                 icons in the legend. In >90% cases you cannot see a
>                 think in these small raster icons anyway. Also, a new
>                 user would not have the idea to turn this particular
>                 setting off to speed up raster loading. Even I was not
>                 aware of it.
>                 Thanks,
>                 Andreas
>                 Andreas Neumann
>                 Böschacherstrasse 10A
>                 8624 Grüt (Gossau ZH)
>                 Switzerland
>                 _______________________________________________
>                 Qgis-developer mailing list
>                 Qgis-developer at lists.osgeo.org
>                 <mailto:Qgis-developer at lists.osgeo.org>
>                 http://lists.osgeo.org/mailman/listinfo/qgis-developer
