[Qgis-developer] Deactivate raster icon generation by default
Andreas Neumann
a.neumann at carto.net
Thu Jun 27 04:16:31 PDT 2013
Hi Matthias,
Thank you - I don't think the threshold would be too useful. With the
VRT format the problem is probably that potentiall hundred/thousands of
files would have to be opened just to generate this small icon that is
of very limited use.
Thank you for your fix!
Andreas
On Thu, 27 Jun 2013 13:08:54 +0200, Matthias Kuhn wrote:
> On linux it's in ~/.config/QGIS/QGIS2.conf (I believe in every
> distribution).
> Default is still true. It's a really simple fix, I'll just commit it.
> If there's a problem, please complain.
> If there's the demand for it, a threshold size (resolution * bands?)
> could be introduced (for 2.1 I'd say).
> On Don 27 Jun 2013 11:38:22 CEST, Werner Macho wrote:
>> ok .. then i am surprised why deleting the .qgis2 folder helped ..
>> On Thu, Jun 27, 2013 at 11:36 AM, Nathan Woodrow
>> <madmanwoo at gmail.com
>> <mailto:madmanwoo at gmail.com>> wrote:
>> Werner,
>> That setting is not stored in the .qgis2 folder. It will be
>> where
>> ever the settings for QGIS are stored. In windows this in the
>> registry.
>> - Nathan
>> On Thu, Jun 27, 2013 at 7:31 PM, Werner Macho
>> <werner.macho at gmail.com <mailto:werner.macho at gmail.com>> wrote:
>> Hmm . I just tested and looked ..
>> It seems that it is already deactivated by default ..
>> deleting the .qgis2 folder and start from scratch showed
>> that
>> it is not active ..
>> probably it's something from an earlier installation?
>> can anyone confirm?
>> On Thu, Jun 27, 2013 at 11:06 AM, Anita Graser
>> <anitagraser at gmx.at <mailto:anitagraser at gmx.at>> wrote:
>> +1 for "off" by default.
>> On Thu, Jun 27, 2013 at 9:54 AM, Andreas Neumann
>> <a.neumann at carto.net <mailto:a.neumann at carto.net>>
>> wrote:
>> Hi,
>> A discussion on the german fossgis-user group
>> revealed
>> that generating raster previews slows down raster
>> loading a lot. Esp. for VRT raster catalogs.
>> Can we set this setting (Settings -> Options ->
>> Canvas
>> and Legend -> Create Raster Icons (may be slow)) to
>> off by default for new users?
>> I think performance is much more important than
>> raster
>> icons in the legend. In >90% cases you cannot see a
>> think in these small raster icons anyway. Also, a
>> new
>> user would not have the idea to turn this particular
>> setting off to speed up raster loading. Even I was
>> not
>> aware of it.
>> Thanks,
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andreas Neumann
Switzerland
