[Qgis-developer] Deactivate raster icon generation by default
Tim Sutton lists at linfiniti.com
Sat Jun 29 15:08:19 PDT 2013
+1 to disable by default
Regards
Tim
On Thu, Jun 27, 2013 at 6:16 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi Matthias,
> Thank you - I don't think the threshold would be too useful. With the VRT
> format the problem is probably that potentiall hundred/thousands of files
> would have to be opened just to generate this small icon that is of very
> limited use.
> Thank you for your fix!
> Andreas
> On Thu, 27 Jun 2013 13:08:54 +0200, Matthias Kuhn wrote:
>> On linux it's in ~/.config/QGIS/QGIS2.conf (I believe in every
>> distribution).
>> Default is still true. It's a really simple fix, I'll just commit it.
>> If there's a problem, please complain.
>> If there's the demand for it, a threshold size (resolution * bands?)
>> could be introduced (for 2.1 I'd say).
>> On Don 27 Jun 2013 11:38:22 CEST, Werner Macho wrote:
>>> ok .. then i am surprised why deleting the .qgis2 folder helped ..
>>> On Thu, Jun 27, 2013 at 11:36 AM, Nathan Woodrow <madmanwoo at gmail.com
>>> <mailto:madmanwoo at gmail.com>> wrote:
>>>     Werner,
>>>     That setting is not stored in the .qgis2 folder.  It will be where
>>>     ever the settings for QGIS are stored. In windows this in the
>>>     registry.
>>>     - Nathan
>>>     On Thu, Jun 27, 2013 at 7:31 PM, Werner Macho
>>>     <werner.macho at gmail.com <mailto:werner.macho at gmail.com**>> wrote:
>>>         Hmm . I just tested and looked ..
>>>         It seems that it is already deactivated by default ..
>>>         deleting the .qgis2 folder and start from scratch showed that
>>>         it is not active ..
>>>         probably it's something from an earlier installation?
>>>         can anyone confirm?
>>>         On Thu, Jun 27, 2013 at 11:06 AM, Anita Graser
>>>         <anitagraser at gmx.at <mailto:anitagraser at gmx.at>> wrote:
>>>             +1 for "off" by default.
>>>             On Thu, Jun 27, 2013 at 9:54 AM, Andreas Neumann
>>>             <a.neumann at carto.net <mailto:a.neumann at carto.net>> wrote:
>>>                 Hi,
>>>                 A discussion on the german fossgis-user group revealed
>>>                 that generating raster previews slows down raster
>>>                 loading a lot. Esp. for VRT raster catalogs.
>>>                 Can we set this setting (Settings -> Options -> Canvas
>>>                 and Legend -> Create Raster Icons (may be slow)) to
>>>                 off by default for new users?
>>>                 I think performance is much more important than raster
>>>                 icons in the legend. In >90% cases you cannot see a
>>>                 think in these small raster icons anyway. Also, a new
>>>                 user would not have the idea to turn this particular
>>>                 setting off to speed up raster loading. Even I was not
>>>                 aware of it.
>>>                 Thanks,
>>>                 Andreas
>>>                 Andreas Neumann
>>>                 Böschacherstrasse 10A
>>>                 8624 Grüt (Gossau ZH)
>>>                 Switzerland
>>>                 ______________________________**_________________
>>>                 Qgis-developer mailing list
>>>                 Qgis-developer at lists.osgeo.org
>>>                 <mailto:Qgis-developer at lists.**osgeo.org<Qgis-developer at lists.osgeo.org>
>>>                 http://lists.osgeo.org/**mailman/listinfo/qgis-**
>>> developer <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>             http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Andreas Neumann
> Switzerland
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130630/df633875/attachment.html>
