[Qgis-developer] New OpenStreetMap integration
Borys Jurgiel lists at borysjurgiel.pl
Sat Mar 2 04:07:51 PST 2013
Dnia piątek, 1 marca 2013 o 08:23:58 Martin Dobias napisał(a):
> On Fri, Mar 1, 2013 at 12:03 AM, Borys Jurgiel <lists at borysjurgiel.pl>
wrote:
> > Dnia czwartek, 28 lutego 2013 o 23:48:48 Martin Dobias napisał(a):
> > First, InitSpatialMetadata() doesn't accept any parameters (AFAIK before
> > version 3.0.2). After removing the crs string from there the conversion
> > went with no errors, but the created db has no geometry columns.
> > Here are the osm & db files: http://tmp.borysjurgiel.pl/testosm.tar.gz
> Your DB file looks good: it has all the _topological_ tables fully
> populated. Now you just need to export data you need (with tags you
> need) to SpatiaLite tables.
Right. Seems I was too excited to read carrefuly your instructions ;)
Now it works perfectly with 3.0.0
