[Qgis-developer] Test dataset for SEXTANTE unit tests?
Tim Sutton lists at linfiniti.com
Sat Mar 2 11:53:47 PST 2013
Hi
On Fri, Mar 1, 2013 at 8:52 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 01/03/2013 07:50, Alexander Bruy ha scritto:
>> Hi Victor,
>> there is a QGIS sample dataset [0], that contains data (both vector
>> and raster) in different formats. There are shapefile, kml, csv and
>> even small grass location. Maybe it makes sence to extent this
>> datased by adding necessary files?
> Hi all.
> I would be in favour of having just one comprehensive sample dataset, used for all,
> including tests.
> I can also help if necessary.
Paolo I don't know if it makes sense to do that - for unit tests the
emphasis should be minimal datasets that represent something that
causes a regression or verifies functional capability. For this reason
we will probably end up with many (hundreds) of small shp (often with
only one or a few features) and other datasets over time each
representing the conditions for a known issue.
Sample data on the other hand should be thematic and provide
sufficient breadth for users to try out the key features of QGIS
without trying to express every edge case they may encounter.
Regards
Tim
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlEwUEsACgkQ/NedwLUzIr57QQCgrRGgVRI9h6NUNlGE2w8izDxM
> pxkAni5iuYAj94lEv3cGjAdtfuStermt
> =U9nd
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
