[Qgis-developer] Print composer feature request
Olivier Dalang olivier.dalang at gmail.com
Sun Mar 3 04:32:20 PST 2013
Hi!
A copy/paste extents feature would also be very useful when working with a
lot of similar maps (that would fit very well in a contextual menu and
reasonably well next to the «set extent» button)
Olivier
On Feb 28, 2013 5:33 PM, "Andreas Neumann" <a.neumann at carto.net> wrote:
> +1 for such a shortcut in the toolbar (with a drop-down menu if there are
> several maps?) or with a right-click context menu.
> I also find the current way of setting the extent quite complicated.
> Andreas
> On Thu, 28 Feb 2013 08:17:06 -0800 (PST), Régis Haubourg wrote:
>> Hi All,
>> before creating a ticket, I would like to discuss a small new feature with
>> you.
>> Setting a map extent to current MapCanvas extent is not quite simple for
>> users that want to open a map composer, rezoom it and print. The question
>> is
>> frequently asked to me.
>>  User has to select the map with the select tool first, then find the item
>> properties tab, then scroll to find the right button in the extent
>> collapsible group.
>> I'm wondering how we could have some kind of shortcut to 'Set to map
>> canvas
>> extent' somewhere.
>> Could we imagine button in the toolbar next to select and navigate tool,
>> greyed out if no map object is selected? Any objection to that?
>> I was also thinking of starting to enable right clic contextual menu on
>> objects, but that would need to some more options.
>> régis
>> View this message in context:
>> http://osgeo-org.1560.n6.**nabble.com/Print-composer-**
>> feature-request-tp5037542.html<http://osgeo-org.1560.n6.nabble.com/Print-composer-feature-request-tp5037542.html>
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> ______________________________**_________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130303/a37a31ed/attachment.html>
