[Qgis-developer] Labeling of starts and ends of a line
Andreas Neumann
a.neumann at carto.net
Tue Mar 5 13:02:58 PST 2013
Sounds interesting to me. Cartographers would love it! Esp. the dragging
along a line. Sounds like something for QGIS 2.1.
The other thing that bothers me a lot is the efficient (performant)
labeling of banana-shaped polygons ... this would be kind if it could
still be fixed in QGIS 2.0. But I'd be also patient and wait for 2.1 ;-)
Thanks a lot,
Andreas
On 3/5/13 9:16 PM, Larry Shaffer wrote:
> Hi,
> I have an idea concerning this that was originally cooked up for an
> approach to doing multi-line curved labels [0]. I refer to them as
> 'label anchors,' which would be for line and polygon features (though
> they could be handy for point features). The concept is roughly like so:
> * An anchor point is sent into PAL that constrains where a single
> label candidate is generated. The point could be data defined or a
> reference to a calculate-able point, e.g. midpoint, beginning/end,
> leftmost/rightmost, nearest point on on line relative to off-line
> point, point furthest from extent center, etc..
> * With data defined anchors, a map tool could be made that allows the
> user to visualize and dynamically move the anchor along a line or even
> place the anchor off the line (e.g., over a nearby related feature,
> like a building-to-street relationship). This would allow data defined
> curved labels to work like moving text along a path in an illustration
> program, and allow for precise control over label placement along a
> line without forcing full pinning of the label.
> * Additional options could be weighting the above/below line labeling
> option (for off-line anchors), and quadrant and offset placement of
> the label relative to anchor.
> There may be other advantages to sending controllable label anchor
> points into PAL. This is different than data defined x/y, which
> totally skips chosen placement algorithms and essentially treats the
> feature geometry as a point. Right now it is just conceptual, and I'd
> like to hear some feedback.
> Regards,
> Larry
> [0] http://hub.qgis.org/issues/4442
> On Tue, Mar 5, 2013 at 12:24 PM, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> Hi,
> So this sounds like its not happening any time soon. Definitely
> after QGIS 2.0
> In this case I will do a helper layer and restrict that line using
> linear referencing. My data is in Postgis and I can use its linear
> referencing functions.
> For the long run I would want to get rid of that helper layer and
> find a QGIS only solution.
> Thanks for your reply!
> Andreas
> On 3/5/13 8:13 PM, Martin Dobias wrote:
> Hi Andreas
> On Tue, Mar 5, 2013 at 2:20 PM, Andreas Neumann
> <a.neumann at carto.net <mailto:a.neumann at carto.net>> wrote:
> Hi,
> Maybe Larry, Martin or Marco can answer this:
> I am looking for the possibility to label a line at the
> start or end (plus a
> given offset from start/end). As far as I know this is not
> yet possible now?
> Does PAL support this and is it a matter of exposing this
> option in the GUI
> or is this not yet supported at all?
> That's not supported as far as I know. It would be handy to have a
> functionality in PAL that would allow us to constrain where
> the label
> candidates should be created and how they should be
> prioritized. That
> would also allow us to decide where to put labels for point
> features
> and which positions are preferred.
> Martin
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130305/2390aaf4/attachment.html>
