[Qgis-developer] Missing icons qgis-dev OSGeo4W
Nathan Woodrow madmanwoo at gmail.com
Thu Mar 7 22:01:50 PST 2013
Thanks.  They are both empty.  Can they be installed using OSGeo4W?
- Nathan
On Fri, Mar 8, 2013 at 3:58 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Nathan,
> On Thu, Mar 7, 2013 at 8:36 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> I have just updated my OSGeo4W install and a lot of the icons for my
>> qgis-dev build are missing.  Just blank push buttons for things like Enable
>> Editing, most of the label options, and some of the other tools.
>> Anyone know what be causing this, or a way to fix it?
> Sounds like an issue with SVG rendering. Those are some of the newer icons
> that have been switched over to SVG-only (regardless of theme). Maybe check
> your C:\OSGeo4W\apps\qt4\plugins dir in imageformats and iconengines to
> make sure your Qt SVG dlls are actually there?
> Regards,
> Larry
>> - Nathan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130308/17a3cb12/attachment.html>
