[Qgis-developer] Missing icons qgis-dev OSGeo4W
Larry Shaffer
larrys at dakotacarto.com
Fri Mar 8 03:32:08 PST 2013
Hi Nathan,
On Thu, Mar 7, 2013 at 11:01 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Thanks. They are both empty. Can they be installed using OSGeo4W?
That's odd; seems like those dlls should always be installed along with
'qt4-libs'. Means that Qt run time currently only has built-in support for
PNG. Did you just install 'qt4-devel' and not 'qt4-libs' ?
Regards,
Larry
> - Nathan
> On Fri, Mar 8, 2013 at 3:58 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
>> Hi Nathan,
>> On Thu, Mar 7, 2013 at 8:36 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>>> I have just updated my OSGeo4W install and a lot of the icons for my
>>> qgis-dev build are missing. Just blank push buttons for things like Enable
>>> Editing, most of the label options, and some of the other tools.
>>> Anyone know what be causing this, or a way to fix it?
>> Sounds like an issue with SVG rendering. Those are some of the newer
>> icons that have been switched over to SVG-only (regardless of theme). Maybe
>> check your C:\OSGeo4W\apps\qt4\plugins dir in imageformats and iconengines
>> to make sure your Qt SVG dlls are actually there?
>> Regards,
>> Larry
>>> - Nathan
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130308/e476dd59/attachment.html>
