[Qgis-developer] No rule to make target staged_plugins
Larry Shaffer larrys at dakotacarto.com
Fri Mar 8 04:28:08 PST 2013
On Fri, Mar 8, 2013 at 4:49 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, Mar 08, 2013 at 04:38:30AM -0700, Larry Shaffer wrote:
> > On Fri, Mar 8, 2013 at 4:25 AM, Sandro Santilli <strk at keybit.net> wrote:
> > > /me thinks the macro should be always available
> > Not sure I understand what you mean. The macro is still always run. Under
> > the new setup, only the build directory staging is optional, though all
> > targets should always be created, including those for staging. The new
> > setup just give options on when and which ones are built
> http://osgeo-org.1560.n6.nabble.com/Update-to-staged-plugins-td5035036.html
> Sorry, I wasn't in sync with latest changes.
> I like the availability of multiple rules, althought I don't see
> any reason, beside speed, to not always stage-install (is there any?).
Not really. Just for speed of building. The staging is quicker as it now
checks if any files have changed before deciding to copy them. However, it
still takes quite a bit more time than not staging at all (significantly
more time on some platforms, slower boxes or virtual machines). So, I now
always leave cmake option for staging off, then run the additional make
commands as needed.
How much time it saves is relative to how often you build, I guess. I'm
doing a multiple daily builds on 3 different platforms for GUI testing now
and the compile time savings really add up.
Larry
> --strk;
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130308/b61007ab/attachment.html>
