[Qgis-developer] No rule to make target staged_plugins
Sandro Santilli strk at keybit.net
Fri Mar 8 03:49:50 PST 2013
On Fri, Mar 08, 2013 at 04:38:30AM -0700, Larry Shaffer wrote:
> On Fri, Mar 8, 2013 at 4:25 AM, Sandro Santilli <strk at keybit.net> wrote:
> > /me thinks the macro should be always available
> Not sure I understand what you mean. The macro is still always run. Under
> the new setup, only the build directory staging is optional, though all
> targets should always be created, including those for staging. The new
> setup just give options on when and which ones are built
> http://osgeo-org.1560.n6.nabble.com/Update-to-staged-plugins-td5035036.html
Sorry, I wasn't in sync with latest changes.
I like the availability of multiple rules, althought I don't see
any reason, beside speed, to not always stage-install (is there any?).
--strk;
