[Qgis-developer] No rule to make target staged_plugins
Radim Blazek
radim.blazek at gmail.com
Tue Mar 12 02:34:28 PDT 2013
On Tue, Mar 12, 2013 at 10:18 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Tue, Mar 12, 2013 at 10:05:59AM +0100, Radim Blazek wrote:
>> On Mon, Mar 11, 2013 at 6:46 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> > Hi Radim,
>> > Could you start an issue ticket for this, possibly including some specs,
>> > like which version of cmake, compiler, etc.? I can not discern what might be
>> > causing the problem for your setup, but working for everyone else (I'm
>> > assuming that), and would like to exchange some patches since I can't
>> > reproduce it here.
>> We have enough serious issues, is not sufficient to set
>> WITH_STAGED_PLUGINS=OFF by default?
> I think the default should be that output/bin/qgis works and can load
> all new core plugins, so developers can test and users can use multiple
> versions. That seems to currently mean "staged plugins".
> I can't find any issue filed on hub where [Subject contains "staged"]
> You mentioned that WITH_STAGED_PLUGINS=OFF works for you, right ?
> Does "make staged-plugins" work after that ?
Yes, as I already reported. It is
make staged-plugins-on-build
causing the problem:
*** No rule to make target `staged-plugins', needed by
`python/plugins/CMakeFiles/staged-plugins-on-build'. Stop.
Radim
> --strk;
