[Qgis-developer] No rule to make target staged_plugins
Sandro Santilli strk at keybit.net
Tue Mar 12 02:18:20 PDT 2013
On Tue, Mar 12, 2013 at 10:05:59AM +0100, Radim Blazek wrote:
> On Mon, Mar 11, 2013 at 6:46 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> > Hi Radim,
> > Could you start an issue ticket for this, possibly including some specs,
> > like which version of cmake, compiler, etc.? I can not discern what might be
> > causing the problem for your setup, but working for everyone else (I'm
> > assuming that), and would like to exchange some patches since I can't
> > reproduce it here.
> We have enough serious issues, is not sufficient to set
> WITH_STAGED_PLUGINS=OFF by default?
I think the default should be that output/bin/qgis works and can load
all new core plugins, so developers can test and users can use multiple
versions. That seems to currently mean "staged plugins".
I can't find any issue filed on hub where [Subject contains "staged"]
You mentioned that WITH_STAGED_PLUGINS=OFF works for you, right ?
Does "make staged-plugins" work after that ?
--strk;
