[Qgis-developer] No rule to make target staged_plugins
Radim Blazek
radim.blazek at gmail.com
Tue Mar 12 02:05:59 PDT 2013
On Mon, Mar 11, 2013 at 6:46 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi Radim,
> Could you start an issue ticket for this, possibly including some specs,
> like which version of cmake, compiler, etc.? I can not discern what might be
> causing the problem for your setup, but working for everyone else (I'm
> assuming that), and would like to exchange some patches since I can't
> reproduce it here.
We have enough serious issues, is not sufficient to set
WITH_STAGED_PLUGINS=OFF by default?
Radim
> Thanks,
> Larry
> On Fri, Mar 8, 2013 at 7:20 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Fri, Mar 8, 2013 at 2:28 PM, Larry Shaffer <larrys at dakotacarto.com>
>> wrote:
>> > Hi,
>> > On Fri, Mar 8, 2013 at 5:47 AM, Radim Blazek <radim.blazek at gmail.com>
>> > wrote:
>> >> On Fri, Mar 8, 2013 at 12:17 PM, Larry Shaffer <larrys at dakotacarto.com>
>> >> wrote:
>> >> > Hi Radim,
>> >> > On Fri, Mar 8, 2013 at 3:31 AM, Radim Blazek <radim.blazek at gmail.com>
>> >> > wrote:
>> >> >> I am getting this compilation error:
>> >> >> make[2]: *** No rule to make target `staged_plugins', needed by
>> >> >> `python/plugins/CMakeFiles/staged_plugins_on_build'. Stop.
>> >> >> make[1]: ***
>> >> >> [python/plugins/CMakeFiles/staged_plugins_on_build.dir/all]
>> >> >> Error 2
>> >> >> How to solve it ?
>> >> > The staged_plugins_on_build target is created when
>> >> > WITH_STAGED_PLUGINS
>> >> > is
>> >> > set to TRUE [0]. I believe the dependent target staged_plugins should
>> >> > always
>> >> > be created if WITH_BINDINGS is TRUE. The new staged plugins setup was
>> >> > committed over a month ago, with no appreciable changes since then
>> >> > [1].
>> >> It may be that I did not recompile last month. Does it require any new
>> >> dependency?
>> >> > What is the make command you ran?
>> >> make
>> >> > Did you try re-generating the cmake build files?
>> >> Yes.
>> >> > Does this happen on make (all target) for the project with an empty
>> >> > build
>> >> > dir?
>> >> Yes, but with copy of CMakeCache.txt from the old one.
>> > Maybe set WITH_STAGED_PLUGINS to FALSE (it's TRUE by default), possibly
>> > skipping the build error, since that problematic target won't be
>> > auto-built.
>> Compiles OK.
>> > Then, if successful build, try 'make staged_plugins' to stage the
>> > plugins to
>> > the build directory, if you run QGIS from there.
>> Works OK, but if I set WITH_STAGED_PLUGINS=ON, make fails again, more
>> verbose output:
>> [ 95%] Built target staged_plugins
>> make -f python/plugins/CMakeFiles/staged_plugins_on_build.dir/build.make
>> python/plugins/CMakeFiles/staged_plugins_on_build.dir/depend
>> make[2]: Entering directory `/home/radim/devel/qgis/build'
>> cd /home/radim/devel/qgis/build && /usr/bin/cmake -E cmake_depends
>> "Unix Makefiles" /home/radim/devel/qgis
>> /home/radim/devel/qgis/python/plugins /home/radim/devel/qgis/build
>> /home/radim/devel/qgis/build/python/plugins
>> /home/radim/devel/qgis/build/python/plugins/CMakeFiles/staged_plugins_on_build.dir/DependInfo.cmake
>> --color=
>> make[2]: Leaving directory `/home/radim/devel/qgis/build'
>> make[1]: *** [python/plugins/CMakeFiles/staged_plugins_on_build.dir/all]
>> Error 2
>> make[1]: Leaving directory `/home/radim/devel/qgis/build'
>> make: *** [all] Error 2
>> Radim
>> >> > What, if anything, has changed in your cmake setup between your last
>> >> > successful build and this error?
>> >> Nothing changed I think, I did git pull and when make failed I run
>> >> ccmake. I saw that some new strange things are missing, so I installed
>> >> bzr but I have still: DART_ROOT-NOTFOUND, HGCOMMAND-NOTFOUND,
>> >> QSCINTILLA_LIBRARY-NOTFOUND - are those necessary?
>> > QSCINTILLA_LIBRARY is the C++ library used by the Qsci Python module,
>> > used
>> > in the new PyQGIS console. Currently only the Python module is linked to
>> > it,
>> > i.e. no one has used QScintilla in C++ code. So, while it shouldn't
>> > matter
>> > for current building if not found, it should have been found by the
>> > .cmake
>> > script.
>> > Not sure about the others. DART is probably for reporting test results
>> > to
>> > the dashboard at [0].
>> > [0] http://dash.orfeo-toolbox.org/index.php?project=QGIS
>> > Regards,
>> > Larry
>> >> Radim
>> >> > Regards,
>> >> > Larry
>> >> > [0]
>> >> > https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/CMakeLists.txt
>> >> > [1]
>> >> > https://github.com/qgis/Quantum-GIS/commit/7717aeed1ca9f81107b72bac3aa127767d8f5ac0
>> >> >> Radim
>> >> >> _______________________________________________
>> >> >> Qgis-developer mailing list
>> >> >> Qgis-developer at lists.osgeo.org
>> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
