[Qgis-developer] No rule to make target staged_plugins
Larry Shaffer larrys at dakotacarto.com
Mon Mar 11 10:46:24 PDT 2013
Hi Radim,
Could you start an issue ticket for this, possibly including some specs,
like which version of cmake, compiler, etc.? I can not discern what might
be causing the problem for your setup, but working for everyone else (I'm
assuming that), and would like to exchange some patches since I can't
reproduce it here.
Thanks,
Larry
On Fri, Mar 8, 2013 at 7:20 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Fri, Mar 8, 2013 at 2:28 PM, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
> > Hi,
> > On Fri, Mar 8, 2013 at 5:47 AM, Radim Blazek <radim.blazek at gmail.com>
> wrote:
> >> On Fri, Mar 8, 2013 at 12:17 PM, Larry Shaffer <larrys at dakotacarto.com>
> >> wrote:
> >> > Hi Radim,
> >> > On Fri, Mar 8, 2013 at 3:31 AM, Radim Blazek <radim.blazek at gmail.com>
> >> > wrote:
> >> >> I am getting this compilation error:
> >> >> make[2]: *** No rule to make target `staged_plugins', needed by
> >> >> `python/plugins/CMakeFiles/staged_plugins_on_build'.  Stop.
> >> >> make[1]: ***
> >> >> [python/plugins/CMakeFiles/staged_plugins_on_build.dir/all]
> >> >> Error 2
> >> >> How to solve it ?
> >> > The staged_plugins_on_build target is created when WITH_STAGED_PLUGINS
> >> > is
> >> > set to TRUE [0]. I believe the dependent target staged_plugins should
> >> > always
> >> > be created if WITH_BINDINGS is TRUE. The new staged plugins setup was
> >> > committed over a month ago, with no appreciable changes since then
> [1].
> >> It may be that I did not recompile last month. Does it require any new
> >> dependency?
> >> > What is the make command you ran?
> >> make
> >> > Did you try re-generating the cmake build files?
> >> Yes.
> >> > Does this happen on make (all target) for the project with an empty
> >> > build
> >> > dir?
> >> Yes, but with copy of CMakeCache.txt from the old one.
> > Maybe set WITH_STAGED_PLUGINS to FALSE (it's TRUE by default), possibly
> > skipping the build error, since that problematic target won't be
> auto-built.
> Compiles OK.
> > Then, if successful build, try 'make staged_plugins' to stage the
> plugins to
> > the build directory, if you run QGIS from there.
> Works OK, but if I set WITH_STAGED_PLUGINS=ON, make fails again, more
> verbose output:
> [ 95%] Built target staged_plugins
> make -f python/plugins/CMakeFiles/staged_plugins_on_build.dir/build.make
> python/plugins/CMakeFiles/staged_plugins_on_build.dir/depend
> make[2]: Entering directory `/home/radim/devel/qgis/build'
> cd /home/radim/devel/qgis/build && /usr/bin/cmake -E cmake_depends
> "Unix Makefiles" /home/radim/devel/qgis
> /home/radim/devel/qgis/python/plugins /home/radim/devel/qgis/build
> /home/radim/devel/qgis/build/python/plugins
> /home/radim/devel/qgis/build/python/plugins/CMakeFiles/staged_plugins_on_build.dir/DependInfo.cmake
> --color=
> make[2]: Leaving directory `/home/radim/devel/qgis/build'
> make[1]: *** [python/plugins/CMakeFiles/staged_plugins_on_build.dir/all]
> Error 2
> make[1]: Leaving directory `/home/radim/devel/qgis/build'
> make: *** [all] Error 2
> Radim
> >> > What, if anything, has changed in your cmake setup between your last
> >> > successful build and this error?
> >> Nothing changed I think, I did git pull and when make failed I run
> >> ccmake. I saw that some new strange things are missing, so I installed
> >> bzr but I have still: DART_ROOT-NOTFOUND, HGCOMMAND-NOTFOUND,
> >> QSCINTILLA_LIBRARY-NOTFOUND - are those necessary?
> > QSCINTILLA_LIBRARY is the C++ library used by the Qsci Python module,
> used
> > in the new PyQGIS console. Currently only the Python module is linked to
> it,
> > i.e. no one has used QScintilla in C++ code. So, while it shouldn't
> matter
> > for current building if not found, it should have been found by the
> .cmake
> > script.
> > Not sure about the others. DART is probably for reporting test results to
> > the dashboard at [0].
> > [0] http://dash.orfeo-toolbox.org/index.php?project=QGIS
> > Regards,
> > Larry
> >> Radim
> >> > Regards,
> >> > Larry
> >> > [0]
> https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/CMakeLists.txt
> >> > [1]
> https://github.com/qgis/Quantum-GIS/commit/7717aeed1ca9f81107b72bac3aa127767d8f5ac0
> >> >> Radim
> >> >> _______________________________________________
> >> >> Qgis-developer mailing list
> >> >> Qgis-developer at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130311/285c0c2d/attachment-0001.html>
