[Qgis-developer] No rule to make target staged_plugins
Radim Blazek radim.blazek at gmail.com
Fri Mar 8 06:20:10 PST 2013
On Fri, Mar 8, 2013 at 2:28 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi,
> On Fri, Mar 8, 2013 at 5:47 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Fri, Mar 8, 2013 at 12:17 PM, Larry Shaffer <larrys at dakotacarto.com>
>> wrote:
>> > Hi Radim,
>> > On Fri, Mar 8, 2013 at 3:31 AM, Radim Blazek <radim.blazek at gmail.com>
>> > wrote:
>> >> I am getting this compilation error:
>> >> make[2]: *** No rule to make target `staged_plugins', needed by
>> >> `python/plugins/CMakeFiles/staged_plugins_on_build'.  Stop.
>> >> make[1]: ***
>> >> [python/plugins/CMakeFiles/staged_plugins_on_build.dir/all]
>> >> Error 2
>> >> How to solve it ?
>> > The staged_plugins_on_build target is created when WITH_STAGED_PLUGINS
>> > is
>> > set to TRUE [0]. I believe the dependent target staged_plugins should
>> > always
>> > be created if WITH_BINDINGS is TRUE. The new staged plugins setup was
>> > committed over a month ago, with no appreciable changes since then [1].
>> It may be that I did not recompile last month. Does it require any new
>> dependency?
>> > What is the make command you ran?
>> make
>> > Did you try re-generating the cmake build files?
>> Yes.
>> > Does this happen on make (all target) for the project with an empty
>> > build
>> > dir?
>> Yes, but with copy of CMakeCache.txt from the old one.
> Maybe set WITH_STAGED_PLUGINS to FALSE (it's TRUE by default), possibly
> skipping the build error, since that problematic target won't be auto-built.
Compiles OK.
> Then, if successful build, try 'make staged_plugins' to stage the plugins to
> the build directory, if you run QGIS from there.
Works OK, but if I set WITH_STAGED_PLUGINS=ON, make fails again, more
verbose output:
[ 95%] Built target staged_plugins
make -f python/plugins/CMakeFiles/staged_plugins_on_build.dir/build.make
python/plugins/CMakeFiles/staged_plugins_on_build.dir/depend
make[2]: Entering directory `/home/radim/devel/qgis/build'
cd /home/radim/devel/qgis/build && /usr/bin/cmake -E cmake_depends
"Unix Makefiles" /home/radim/devel/qgis
/home/radim/devel/qgis/python/plugins /home/radim/devel/qgis/build
/home/radim/devel/qgis/build/python/plugins
/home/radim/devel/qgis/build/python/plugins/CMakeFiles/staged_plugins_on_build.dir/DependInfo.cmake
--color=
make[2]: Leaving directory `/home/radim/devel/qgis/build'
make[1]: *** [python/plugins/CMakeFiles/staged_plugins_on_build.dir/all] Error 2
make[1]: Leaving directory `/home/radim/devel/qgis/build'
make: *** [all] Error 2
Radim
>> > What, if anything, has changed in your cmake setup between your last
>> > successful build and this error?
>> Nothing changed I think, I did git pull and when make failed I run
>> ccmake. I saw that some new strange things are missing, so I installed
>> bzr but I have still: DART_ROOT-NOTFOUND, HGCOMMAND-NOTFOUND,
>> QSCINTILLA_LIBRARY-NOTFOUND - are those necessary?
> QSCINTILLA_LIBRARY is the C++ library used by the Qsci Python module, used
> in the new PyQGIS console. Currently only the Python module is linked to it,
> i.e. no one has used QScintilla in C++ code. So, while it shouldn't matter
> for current building if not found, it should have been found by the .cmake
> script.
> Not sure about the others. DART is probably for reporting test results to
> the dashboard at [0].
> [0] http://dash.orfeo-toolbox.org/index.php?project=QGIS
> Regards,
> Larry
>> Radim
>> > Regards,
>> > Larry
>> > [0]
>> > https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/CMakeLists.txt
>> > [1]
>> > https://github.com/qgis/Quantum-GIS/commit/7717aeed1ca9f81107b72bac3aa127767d8f5ac0
>> >> Radim
>> >> _______________________________________________
>> >> Qgis-developer mailing list
>> >> Qgis-developer at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
