[Qgis-developer] Feature freeze commencing the ides of March
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Mar 13 09:44:13 PDT 2013
Hi devs
The first part of the symbology improvements is available in my github fork:
https://github.com/mhugent/Quantum-GIS/tree/data_defined_symbology
Currently, one symbol is either in mm or in map units. The changeset in
the branch adds the possibility to mix different output units ( mm / map
units ) in one symbol and even in one symbol layer. So it is now e.g.
possible to have line width in mm and line offset in map units.
Let me know if you have feedback on this. Next enhancement part will be
to add more data defined symbol properties (from attribute / expression).
Regards,
Marco
On 04.03.2013 13:07, Marco Hugentobler wrote:
>> Moving the date to say start of April wouldn't
>> hurt.  Would that help?
> Start of April would be ok for the data defined symbology.
> Regards,
> Marco
> On 04.03.2013 11:44, Jürgen E. Fischer wrote:
>> Hi Marco,
>> On Mon, 04. Mar 2013 at 11:37:15 +0100, Marco Hugentobler wrote:
>>> Disadvantage is that 15 March is too close for it to go into master.
>>> What
>>> should we do (wait for 2.1 /  shift feature freeze date / exception
>>> from
>>> feature freeze) ?
>> How much time would you need?  Moving the date to say start of April
>> wouldn't
>> Jürgen
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
