[Qgis-developer] Feature freeze commencing the ides of March
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Mar 15 08:44:06 PDT 2013
Pushed to master branch now.
On 13.03.2013 17:44, Marco Hugentobler wrote:
> Hi devs
> The first part of the symbology improvements is available in my github
> fork:
> https://github.com/mhugent/Quantum-GIS/tree/data_defined_symbology
> Currently, one symbol is either in mm or in map units. The changeset
> in the branch adds the possibility to mix different output units ( mm
> / map units ) in one symbol and even in one symbol layer. So it is now
> e.g. possible to have line width in mm and line offset in map units.
> Let me know if you have feedback on this. Next enhancement part will
> be to add more data defined symbol properties (from attribute /
> expression).
> Regards,
> Marco
> On 04.03.2013 13:07, Marco Hugentobler wrote:
>>> Moving the date to say start of April wouldn't
>>> hurt.  Would that help?
>> Start of April would be ok for the data defined symbology.
>> Regards,
>> Marco
>> On 04.03.2013 11:44, Jürgen E. Fischer wrote:
>>> Hi Marco,
>>> On Mon, 04. Mar 2013 at 11:37:15 +0100, Marco Hugentobler wrote:
>>>> Disadvantage is that 15 March is too close for it to go into
>>>> master. What
>>>> should we do (wait for 2.1 /  shift feature freeze date / exception
>>>> from
>>>> feature freeze) ?
>>> How much time would you need?  Moving the date to say start of April
>>> wouldn't
>>> Jürgen
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
