[Qgis-developer] Feature freeze commencing the ides of March
Tim Sutton
lists at linfiniti.com
Fri Mar 15 14:55:52 PDT 2013
Hi All
Just to confirm on this thread that following the discussions here the
following updated timeline to 2.0 will apply:
1 April 2013 - Feature freeze - no new features in master
1 May 2013 - GUI Freeze and String freeze - no changes to ui or
strings except where required for critical bug fixes. Call for
translations.
1 June 2013 - Branch 2.0, code freeze (except for packaging related
changes), call for packaging
7 June 2013 - Public release of 2.0
Regards
Tim
On Fri, Mar 15, 2013 at 5:44 PM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
> Pushed to master branch now.
> On 13.03.2013 17:44, Marco Hugentobler wrote:
>> Hi devs
>> The first part of the symbology improvements is available in my github
>> fork:
>> https://github.com/mhugent/Quantum-GIS/tree/data_defined_symbology
>> Currently, one symbol is either in mm or in map units. The changeset in
>> the branch adds the possibility to mix different output units ( mm / map
>> units ) in one symbol and even in one symbol layer. So it is now e.g.
>> possible to have line width in mm and line offset in map units.
>> Let me know if you have feedback on this. Next enhancement part will be to
>> add more data defined symbol properties (from attribute / expression).
>> Regards,
>> Marco
>> On 04.03.2013 13:07, Marco Hugentobler wrote:
>>>> Moving the date to say start of April wouldn't
>>>> hurt. Would that help?
>>> Start of April would be ok for the data defined symbology.
>>> Regards,
>>> Marco
>>> On 04.03.2013 11:44, Jürgen E. Fischer wrote:
>>>> Hi Marco,
>>>> On Mon, 04. Mar 2013 at 11:37:15 +0100, Marco Hugentobler wrote:
>>>>> Disadvantage is that 15 March is too close for it to go into master.
>>>>> What
>>>>> should we do (wait for 2.1 / shift feature freeze date / exception
>>>>> from
>>>>> feature freeze) ?
>>>> How much time would you need? Moving the date to say start of April
>>>> wouldn't
>>>> Jürgen
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
