[Qgis-developer] Feature freeze commencing the ides of March
Olivier Dalang olivier.dalang at gmail.com
Tue Mar 19 16:34:04 PDT 2013
Hi !
Just for information :
- will QGis 2.0 have the PyQt API changed to version 2 ?
- will it have a separate plugin folder than QGis 1.8 ?
Thanks !
Olivier
2013/3/15 Tim Sutton <lists at linfiniti.com>
> Hi All
> Just to confirm on this thread that following the discussions here the
> following updated timeline to 2.0 will apply:
> 1 April 2013 - Feature freeze - no new features in master
> 1 May 2013 - GUI Freeze and String freeze - no changes to ui or
> strings except where required for critical bug fixes. Call for
> translations.
> 1 June 2013 - Branch 2.0, code freeze (except for packaging related
> changes), call for packaging
> 7 June 2013 - Public release of 2.0
> Regards
> Tim
> On Fri, Mar 15, 2013 at 5:44 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch> wrote:
> > Pushed to master branch now.
> > On 13.03.2013 17:44, Marco Hugentobler wrote:
> >> Hi devs
> >> The first part of the symbology improvements is available in my github
> >> fork:
> >> https://github.com/mhugent/Quantum-GIS/tree/data_defined_symbology
> >> Currently, one symbol is either in mm or in map units. The changeset in
> >> the branch adds the possibility to mix different output units ( mm / map
> >> units ) in one symbol and even in one symbol layer. So it is now e.g.
> >> possible to have line width in mm and line offset in map units.
> >> Let me know if you have feedback on this. Next enhancement part will be
> to
> >> add more data defined symbol properties (from attribute / expression).
> >> Regards,
> >> Marco
> >> On 04.03.2013 13:07, Marco Hugentobler wrote:
> >>>> Moving the date to say start of April wouldn't
> >>>> hurt.  Would that help?
> >>> Start of April would be ok for the data defined symbology.
> >>> Regards,
> >>> Marco
> >>> On 04.03.2013 11:44, Jürgen E. Fischer wrote:
> >>>> Hi Marco,
> >>>> On Mon, 04. Mar 2013 at 11:37:15 +0100, Marco Hugentobler wrote:
> >>>>> Disadvantage is that 15 March is too close for it to go into master.
> >>>>> What
> >>>>> should we do (wait for 2.1 /  shift feature freeze date / exception
> >>>>> from
> >>>>> feature freeze) ?
> >>>> How much time would you need?  Moving the date to say start of April
> >>>> wouldn't
> >>>> Jürgen
> > Dr. Marco Hugentobler
> > Sourcepole -  Linux & Open Source Solutions
> > Weberstrasse 5, CH-8004 Zürich, Switzerland
> > marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> > Technical Advisor QGIS Project Steering Committee
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130320/8aa80edf/attachment-0001.html>
