[Qgis-developer] Feature freeze commencing the ides of March
Tim Sutton lists at linfiniti.com
Wed Mar 20 07:37:15 PDT 2013
Hi
On Wed, Mar 20, 2013 at 1:34 AM, Olivier Dalang
<olivier.dalang at gmail.com> wrote:
> Hi !
> Just for information :
> - will QGis 2.0 have the PyQt API changed to version 2 ?
I don't understand?
> - will it have a separate plugin folder than QGis 1.8 ?
It would probably make sense for it to have a separate plugin folder
and also a separate QSettings namespace.
Regards
Tim
> Thanks !
> Olivier
> 2013/3/15 Tim Sutton <lists at linfiniti.com>
>> Hi All
>> Just to confirm on this thread that following the discussions here the
>> following updated timeline to 2.0 will apply:
>> 1 April 2013 - Feature freeze - no new features in master
>> 1 May 2013 - GUI Freeze and String freeze - no changes to ui or
>> strings except where required for critical bug fixes. Call for
>> translations.
>> 1 June 2013 - Branch 2.0, code freeze (except for packaging related
>> changes), call for packaging
>> 7 June 2013 - Public release of 2.0
>> Regards
>> Tim
>> On Fri, Mar 15, 2013 at 5:44 PM, Marco Hugentobler
>> <marco.hugentobler at sourcepole.ch> wrote:
>> > Pushed to master branch now.
>> > On 13.03.2013 17:44, Marco Hugentobler wrote:
>> >> Hi devs
>> >> The first part of the symbology improvements is available in my github
>> >> fork:
>> >> https://github.com/mhugent/Quantum-GIS/tree/data_defined_symbology
>> >> Currently, one symbol is either in mm or in map units. The changeset in
>> >> the branch adds the possibility to mix different output units ( mm /
>> >> map
>> >> units ) in one symbol and even in one symbol layer. So it is now e.g.
>> >> possible to have line width in mm and line offset in map units.
>> >> Let me know if you have feedback on this. Next enhancement part will be
>> >> to
>> >> add more data defined symbol properties (from attribute / expression).
>> >> Regards,
>> >> Marco
>> >> On 04.03.2013 13:07, Marco Hugentobler wrote:
>> >>>> Moving the date to say start of April wouldn't
>> >>>> hurt.  Would that help?
>> >>> Start of April would be ok for the data defined symbology.
>> >>> Regards,
>> >>> Marco
>> >>> On 04.03.2013 11:44, Jürgen E. Fischer wrote:
>> >>>> Hi Marco,
>> >>>> On Mon, 04. Mar 2013 at 11:37:15 +0100, Marco Hugentobler wrote:
>> >>>>> Disadvantage is that 15 March is too close for it to go into master.
>> >>>>> What
>> >>>>> should we do (wait for 2.1 /  shift feature freeze date / exception
>> >>>>> from
>> >>>>> feature freeze) ?
>> >>>> How much time would you need?  Moving the date to say start of April
>> >>>> wouldn't
>> >>>> Jürgen
>> > Dr. Marco Hugentobler
>> > Sourcepole -  Linux & Open Source Solutions
>> > Weberstrasse 5, CH-8004 Zürich, Switzerland
>> > marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> > Technical Advisor QGIS Project Steering Committee
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>>  * QGIS programming and support services
>>  * Mapserver and PostGIS based hosting plans
>>  * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
