[Qgis-developer] Feature freeze commencing the ides of March
Olivier Dalang
olivier.dalang at gmail.com
Wed Mar 20 08:32:05 PDT 2013
I was talking about that proposition:
http://osgeo-org.1560.n6.nabble.com/Merging-of-incompatible-changes-td5010325.html
( specifically the part about using the new api, as explained here :
http://pyqt.sourceforge.net/Docs/PyQt4/incompatible_apis.html )
2013/3/20 Tim Sutton <lists at linfiniti.com>
> Hi
> On Wed, Mar 20, 2013 at 1:34 AM, Olivier Dalang
> <olivier.dalang at gmail.com> wrote:
> > Hi !
> > Just for information :
> > - will QGis 2.0 have the PyQt API changed to version 2 ?
> I don't understand?
> > - will it have a separate plugin folder than QGis 1.8 ?
> It would probably make sense for it to have a separate plugin folder
> and also a separate QSettings namespace.
> Regards
> Tim
> > Thanks !
> > Olivier
> > 2013/3/15 Tim Sutton <lists at linfiniti.com>
> >> Hi All
> >> Just to confirm on this thread that following the discussions here the
> >> following updated timeline to 2.0 will apply:
> >> 1 April 2013 - Feature freeze - no new features in master
> >> 1 May 2013 - GUI Freeze and String freeze - no changes to ui or
> >> strings except where required for critical bug fixes. Call for
> >> translations.
> >> 1 June 2013 - Branch 2.0, code freeze (except for packaging related
> >> changes), call for packaging
> >> 7 June 2013 - Public release of 2.0
> >> Regards
> >> Tim
> >> On Fri, Mar 15, 2013 at 5:44 PM, Marco Hugentobler
> >> <marco.hugentobler at sourcepole.ch> wrote:
> >> > Pushed to master branch now.
> >> > On 13.03.2013 17:44, Marco Hugentobler wrote:
> >> >> Hi devs
> >> >> The first part of the symbology improvements is available in my
> github
> >> >> fork:
> >> >> https://github.com/mhugent/Quantum-GIS/tree/data_defined_symbology
> >> >> Currently, one symbol is either in mm or in map units. The changeset
> in
> >> >> the branch adds the possibility to mix different output units ( mm /
> >> >> map
> >> >> units ) in one symbol and even in one symbol layer. So it is now e.g.
> >> >> possible to have line width in mm and line offset in map units.
> >> >> Let me know if you have feedback on this. Next enhancement part will
> be
> >> >> to
> >> >> add more data defined symbol properties (from attribute /
> expression).
> >> >> Regards,
> >> >> Marco
> >> >> On 04.03.2013 13:07, Marco Hugentobler wrote:
> >> >>>> Moving the date to say start of April wouldn't
> >> >>>> hurt. Would that help?
> >> >>> Start of April would be ok for the data defined symbology.
> >> >>> Regards,
> >> >>> Marco
> >> >>> On 04.03.2013 11:44, Jürgen E. Fischer wrote:
> >> >>>> Hi Marco,
> >> >>>> On Mon, 04. Mar 2013 at 11:37:15 +0100, Marco Hugentobler wrote:
> >> >>>>> Disadvantage is that 15 March is too close for it to go into
> master.
> >> >>>>> What
> >> >>>>> should we do (wait for 2.1 / shift feature freeze date /
> exception
> >> >>>>> from
> >> >>>>> feature freeze) ?
> >> >>>> How much time would you need? Moving the date to say start of
> April
> >> >>>> wouldn't
> >> >>>> Jürgen
> >> > Dr. Marco Hugentobler
> >> > Sourcepole - Linux & Open Source Solutions
> >> > Weberstrasse 5, CH-8004 Zürich, Switzerland
> >> > marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> >> > Technical Advisor QGIS Project Steering Committee
> >> > _______________________________________________
> >> > Qgis-developer mailing list
> >> > Qgis-developer at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> >> Please do not email me off-list with technical
> >> support questions. Using the lists will gain
> >> more exposure for your issues and the knowledge
> >> surrounding your issue will be shared with all.
> >> Visit http://linfiniti.com to find out about:
> >> * QGIS programming and support services
> >> * Mapserver and PostGIS based hosting plans
> >> * FOSS Consulting Services
> >> Skype: timlinux
> >> Irc: timlinux on #qgis at freenode.net
> Skype: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130320/d83086ce/attachment-0001.html>
