[Qgis-developer] Problem using QgsFeature.attributes() instead of QgsFeature.attributeMap() in QGIS 1.9
Alexandre Neto
senhor.neto at gmail.com
Thu Mar 14 02:13:38 PDT 2013
Hello Martin,
Thanks for your answer. You are right, I was not doing it correctly in the
first place.
For 1.8 it "worked" cause I was able to swap each QgsField for a QVariant,
in 1.9 with the QgsFields that is not possible anymore.
So I have changed it for:
if QGis.QGIS_VERSION_INT < 10900:
new_attributes = feature.attributeMap()
for j in range(new_attributes.__len__()):
if not provider.defaultValue(j).isNull():
new_attributes[j] = provider.defaultValue(j)
temp_feature.setAttributeMap(new_attributes)
else:
new_attributes = feature.attributes()
temp_feature.setAttributes(new_attributes)
I don't like the repeated code, but I was not sure if checking for QGIS
version for each attribute was much better.
Thanks again, and sorry for the time wasted, I know you guys are quite busy.
Alexandre Neto
On Wed, Mar 13, 2013 at 8:48 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Alexandre
> On Tue, Mar 12, 2013 at 1:22 AM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > new_attributes = layer.pendingFields()
> > But when using it in 1.9 I got the following error in the line:
> > new_attributes[j] = feature.attributes()[j]
> > Traceback (most recent call last):
> > File "<input>", line x, in <module>
> > TypeError: QgsFields.__setitem__(): argument 2 has unexpected type
> > 'QVariant'
> What are you actually trying to do?
> layer.pendingFields() returns QgsFields instance, which basically acts
> as a list of QgsField instances (attribute definitions). Then, you are
> trying to assign an attribute value (QVariant) to a field - that's
> clearly an error and it is reported correctly. Probably you want to
> copy the attributes to another feature?
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130314/905be53e/attachment.html>
