[Qgis-developer] ECW!!!
kimaidou kimaidou at gmail.com
Fri Mar 15 04:21:51 PDT 2013
Here is a very documented blog post about the comparative use of ecw or
compressed gtiff
http://blog.webmapper.com.au/
You can use basic gdal command line to get a compressed gtiff from ecw,
with very good performances. For example :
# convertir l'ecw
gdal_translate -of GTiff -co "TILED=yes" -co "PHOTOMETRIC=YCBCR" -co
"COMPRESS=JPEG" input.ecw output.tif
# créer la pyramide
gdaladdo -r average --config COMPRESS_OVERVIEW JPEG --config
PHOTOMETRIC_OVERVIEW YCBCR --config INTERLEAVE_OVERVIEW PIXEL
compressed.tif 2 4 8 16 32 64 128
Will provide a geotiff with great performances and not so big compared to
the ecw.
And as other suggested, open source wavelet is in progress too and must be
burried out !
Michael
2013/3/15 <jr.morreale at enoreth.net>
> On 2013-03-15 11:14, Vincent Picavet wrote:
>> I can understand Fred's frustration. Let's see a new plugin in OSGEO4W
>>> sooner than later.
>> It's up to you then.
> I was going to write the same thing, ECW is proprietary viper's nest, the
> work to make it usable on QGIS should be done by ERDAS or by the people
> using it.
> For those wanting a good wavelet format, there is OpenJPEG 2.0. If it
> doesn't fit the bill for you then they should think about supporting it
> like the CNES did instead of asking a open software to support a black box
> with a stupid license.
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130315/ba3d8255/attachment.html>
