[Qgis-developer] ECW!!!
Ecofuego nic at ecogis.com.au
Sun Mar 17 01:58:14 PDT 2013
The instruction I have provided are clear and tried and proven.  I am
successfully using ECW files thanks to Giovanni Manghi's instructions.  I
put them in here so that any user can install the GDAL-plugin simply and
with a minimal number of steps.
It also means that a user does does not paste dlls into the system
directories.  Instead only two files are copied to the appropriate
directories in the OSGEO4W folder.  It is that simple once one has obtained
the GDAL-ecw plugin and the library file from the MSI installer provided by
Giovanni.
View this message in context: http://osgeo-org.1560.n6.nabble.com/RE-ECW-tp4646269p5040920.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
