[Qgis-developer] Measurement in meters
Alex Mandel tech_dev at wildintellect.com
Thu Mar 21 22:37:15 PDT 2013
On 03/20/2013 11:58 PM, Paolo Cavallini wrote:
> Il 21/03/2013 02:26, Alex Mandel ha scritto:
>> It's user configurable in the Project Properties in 1.8. Did that
>> change in master?
>> Or do you mean when projection on the fly is on?
> Yes, OTF on, Project properties > meters. I expected measurements
> in maters, but they are in degrees. Thanks.
Since you mentioned it, I noticed in my 1.8 install that the units
always says m even when in a projection that is feet, but the actual
measurement is correct. Makes me wonder if it's just the units failing
to switch.
Alex
