[Qgis-developer] Measurement in meters
Alex Mandel tech_dev at wildintellect.com
Fri Mar 22 00:07:21 PDT 2013
On 03/21/2013 10:37 PM, Alex Mandel wrote:
> On 03/20/2013 11:58 PM, Paolo Cavallini wrote:
>> Il 21/03/2013 02:26, Alex Mandel ha scritto:
>>> It's user configurable in the Project Properties in 1.8. Did that
>>> change in master?
>>> Or do you mean when projection on the fly is on?
>> Yes, OTF on, Project properties > meters. I expected measurements
>> in maters, but they are in degrees. Thanks.
> Since you mentioned it, I noticed in my 1.8 install that the units
> always says m even when in a projection that is feet, but the actual
> measurement is correct. Makes me wonder if it's just the units failing
> to switch.
> Alex
Hmm, that appears to be the preferred units override...
-Alex
