[Qgis-developer] problem with feature request and updateFeature
Nathan Woodrow
madmanwoo at gmail.com
Fri Mar 22 07:30:28 PDT 2013
Also Denis. You can simplify the code a lot like this:
for f in vectorLayer.getFeatures( QgsFeatureRequest() ):
f[field] = 1
vectorLayer.updateFeature(f)
On Fri, Mar 22, 2013 at 11:10 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
> Yes exactly
> f = QgsFeature()
> iter = vectorLayer.getFeatures( QgsFeatureRequest() )
> while iter.nextFeature( f ):
> print f.id()
> f.setAttribute( field, QVariant( 1 ) )
> vectorLayer.updateFeature( f )
> Prints only 1 id, commenting the last line prints all ids.
> On 03/22/2013 01:56 PM, Nathan Woodrow wrote:
> Do you mean your loop is exited when you call updateFeature?
> Can you post your code.
> - Nathan
> On Fri, Mar 22, 2013 at 10:54 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>> Hi all,
>> I am looping over features of a layer using new API (QgsFeatureRequest).
>> If I modify a feature and do: layer.updateFeature(f), my loop is broken.
>> Is this a normal behavior?
>> What should I do if I want to modify features during the loop?
>> Thanks
>> Denis
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130323/a590dc92/attachment.html>
