[Qgis-developer] problem with feature request and updateFeature
Jürgen E. Fischer jef at norbit.de
Fri Mar 22 08:21:50 PDT 2013
Hi Nathan,
On Sat, 23. Mar 2013 at 00:29:03 +1000, Nathan Woodrow wrote:
> If updateFeature is indeed doing feature request inside and breaking the loop
> then that is a bug.  updateFeature should not affect the feature
The misfeature is that there can only be one active iterator per provider (see
also [1]).  So the feature iterator in updateFeature closes the iterator of the
loop.
> What should I do if I want to modify features during the loop?
replacing
>                      f.setAttribute( field, QVariant( 1 ) )
>                      vectorLayer.updateFeature( f )
with
		       vectorLayer.changeAttributeValue( f.id(), field, 1 )
should help.
Jürgen
[1] http://hub.qgis.org/issues/7071#note-6
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
