[Qgis-developer] Crashes on direct project load
Matthias Kuhn matthias.kuhn at gmx.ch
Wed Mar 27 02:24:34 PDT 2013
Confirmed on Linux (Fedora 18)
Project loads and when finished crashes
qgis --project [path.qgs]
and
qgis [path.qgs]
On Mit 27 Mär 2013 07:59:04 CET, Andreas Neumann wrote:
> Hi,
> I have once again (or still) problems that QGIS is crashing when I
> double click a .qgs File in Windows Explorer. These projects work fine
> if I manually open them, but not if I open them directly on startup. I
> guess double clicking on Windows is the same like the --project
> startup option on the command line - so QGIS may crash on other OS as
> well when using this command line option.
> Not all of my projects crash on startup, but most.
> Can others confirm that?
> Thank you,
> Andreas
