[Qgis-developer] Crashes on direct project load
Matthias Kuhn
matthias.kuhn at gmx.ch
Wed Mar 27 02:28:57 PDT 2013
... fails in loadComposersFromProject ...
On Mit 27 Mär 2013 10:24:34 CET, Matthias Kuhn wrote:
> Confirmed on Linux (Fedora 18)
> Project loads and when finished crashes
> qgis --project [path.qgs]
> and
> qgis [path.qgs]
> On Mit 27 Mär 2013 07:59:04 CET, Andreas Neumann wrote:
>> Hi,
>> I have once again (or still) problems that QGIS is crashing when I
>> double click a .qgs File in Windows Explorer. These projects work fine
>> if I manually open them, but not if I open them directly on startup. I
>> guess double clicking on Windows is the same like the --project
>> startup option on the command line - so QGIS may crash on other OS as
>> well when using this command line option.
>> Not all of my projects crash on startup, but most.
>> Can others confirm that?
>> Thank you,
>> Andreas
