[Qgis-developer] Crashes on direct project load
Andreas Neumann
a.neumann at carto.net
Wed Mar 27 04:15:50 PDT 2013
Hi Matthias,
Thanks for testing - I filed a bug at http://hub.qgis.org/issues/7458
Andreas
On Wed, 27 Mar 2013 10:28:57 +0100, Matthias Kuhn wrote:
> ... fails in loadComposersFromProject ...
> On Mit 27 Mär 2013 10:24:34 CET, Matthias Kuhn wrote:
>> Confirmed on Linux (Fedora 18)
>> Project loads and when finished crashes
>> qgis --project [path.qgs]
>> and
>> qgis [path.qgs]
>> On Mit 27 Mär 2013 07:59:04 CET, Andreas Neumann wrote:
>>> Hi,
>>> I have once again (or still) problems that QGIS is crashing when I
>>> double click a .qgs File in Windows Explorer. These projects work
>>> fine
>>> if I manually open them, but not if I open them directly on
>>> startup. I
>>> guess double clicking on Windows is the same like the --project
>>> startup option on the command line - so QGIS may crash on other OS
>>> as
>>> well when using this command line option.
>>> Not all of my projects crash on startup, but most.
>>> Can others confirm that?
>>> Thank you,
>>> Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
