[Qgis-developer] How to modify QGIS UI at start?
Nathan Woodrow
madmanwoo at gmail.com
Thu May 2 00:24:36 PDT 2013
If you save the ini file out and edit it by hand. It's just a bunch of
true and false switches. You can can then load QGIS using the
--customizationfile your.ini option and it will change the UI on load
QGIS can also take a --code yourpythonfile.py that will run after the
project is loaded.
- Nathan
On Thu, May 2, 2013 at 5:22 PM, Marco Bernasocchi
<marco at bernawebdesign.ch>wrote:
> On 05/01/2013 08:19 PM, db-esm wrote:
>> Yes, but we need to have this happen automatically without users having
>> to do
>> it manually.
>> IIRC you can deploy a customization.ini file, it will be read at startup
> ciao
>> View this message in context: http://osgeo-org.1560.x6.**
>> nabble.com/How-to-modify-QGIS-**UI-at-start-tp5050659p5050686.**html<http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050686.html>
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> ______________________________**_________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Marco Bernasocchi
> http://opengis.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130502/e4b4663f/attachment.html>
