[Qgis-developer] How to modify QGIS UI at start?
db-esm
david at esmarkets.com
Thu May 2 06:31:23 PDT 2013
Does this work on Windows?
Sorry, I should have mentioned from the beginning that we're on Windows.
David
Nathan Woodrow wrote
> If you save the ini file out and edit it by hand. It's just a bunch of
> true and false switches. You can can then load QGIS using the
> --customizationfile your.ini option and it will change the UI on load
> QGIS can also take a --code yourpythonfile.py that will run after the
> project is loaded.
> - Nathan
> On Thu, May 2, 2013 at 5:22 PM, Marco Bernasocchi
> marco@
> >wrote:
>> On 05/01/2013 08:19 PM, db-esm wrote:
>>> Yes, but we need to have this happen automatically without users having
>>> to do
>>> it manually.
>>> IIRC you can deploy a customization.ini file, it will be read at
>>> startup
>> ciao
>>> View this message in context: http://osgeo-org.1560.x6.**
>>> nabble.com/How-to-modify-QGIS-**UI-at-start-tp5050659p5050686.**html<http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050686.html>
>>> Sent from the Quantum GIS - Developer mailing list archive at
>>> Nabble.com.
>>> ______________________________**_________________
>>> Qgis-developer mailing list
> Qgis-developer at .osgeo
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Marco Bernasocchi
>> http://opengis.ch
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050959.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
