[Qgis-developer] How to modify QGIS UI at start?
Nathan Woodrow madmanwoo at gmail.com
Thu May 2 14:32:28 PDT 2013
Yes it works on all platforms.
- Nathan
On Thu, May 2, 2013 at 11:31 PM, db-esm <david at esmarkets.com> wrote:
> Does this work on Windows?
> Sorry, I should have mentioned from the beginning that we're on Windows.
> David
> Nathan Woodrow wrote
> > If you save the ini file out and edit it by hand.  It's just a bunch of
> > true and false switches.  You can can then load QGIS using the
> > --customizationfile your.ini option and it will change the UI on load
> > QGIS can also take a --code yourpythonfile.py that will run after the
> > project is loaded.
> > - Nathan
> > On Thu, May 2, 2013 at 5:22 PM, Marco Bernasocchi
> > marco@
> > >wrote:
> >> On 05/01/2013 08:19 PM, db-esm wrote:
> >>> Yes, but we need to have this happen automatically without users having
> >>> to do
> >>> it manually.
> >>>  IIRC you can deploy a customization.ini file, it will be read at
> >>> startup
> >> ciao
> >>> View this message in context: http://osgeo-org.1560.x6.**
> nabble.com/How-to-modify-QGIS-**UI-at-start-tp5050659p5050686.**html<http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050686.html&gt
> >>> Sent from the Quantum GIS - Developer mailing list archive at
> >>> Nabble.com.
> >>> ______________________________**_________________
> >>> Qgis-developer mailing list
> > Qgis-developer at .osgeo
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer&gt
> >> Marco Bernasocchi
> >> http://opengis.ch
> http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050959.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130503/8b04dde1/attachment.html>
