[Qgis-developer] How to modify QGIS UI at start?
db-esm
david at esmarkets.com
Fri May 3 06:15:53 PDT 2013
When I try to use "code" or "customizationfile" as a command line option, I
get an error message like:
"The layer C:\Users\Public\ThumbImage\--code is not a valid layer and cant
not be added to the map"
The "--configpath" option doesn't result in an error message, but has no
effect: the UI settings are still read from (and written to) the Windows
registry.
Perhaps on Windows, QSettings always uses the registry now?
David
Nathan Woodrow wrote
> Yes it works on all platforms.
> - Nathan
> On Thu, May 2, 2013 at 11:31 PM, db-esm <
> david@
> > wrote:
>> Does this work on Windows?
>> Sorry, I should have mentioned from the beginning that we're on Windows.
>> David
>> > If you save the ini file out and edit it by hand. It's just a bunch of
>> > true and false switches. You can can then load QGIS using the
>> > --customizationfile your.ini option and it will change the UI on load
>> > QGIS can also take a --code yourpythonfile.py that will run after the
>> > project is loaded.
>> > - Nathan
>> > On Thu, May 2, 2013 at 5:22 PM, Marco Bernasocchi
>> > marco@
>> > >wrote:
>> >> On 05/01/2013 08:19 PM, db-esm wrote:
>> >>> Yes, but we need to have this happen automatically without users
>> having
>> >>> to do
>> >>> it manually.
>> >>> IIRC you can deploy a customization.ini file, it will be read at
>> >>> startup
>> >> ciao
>> >>> View this message in context: http://osgeo-org.1560.x6.**
>> nabble.com/How-to-modify-QGIS-**UI-at-start-tp5050659p5050686.**html<http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050686.html>
>> >>> Sent from the Quantum GIS - Developer mailing list archive at
>> >>> Nabble.com.
>> >>> ______________________________**_________________
>> >>> Qgis-developer mailing list
>> > Qgis-developer at .osgeo
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> >> Marco Bernasocchi
>> >> http://opengis.ch
>> > _______________________________________________
>> http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050959.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5051179.html
