[Qgis-developer] Git help needed
Nathan Woodrow madmanwoo at gmail.com
Thu May 2 02:30:59 PDT 2013
Generally you should work and push branches to github and issue pull
requests on those.  It will make it easier to keep your pending commits and
changes out of your master branch so you can update it like normal
git checkout -b mywork
do you stuff..
git commit -m "My changes"
git push origin mywork
Pull request on mywork branch.
You can then keep master in line by doing:
git checkout master
git pull --rebase upstream/master
upstream == QGIS github repo, might be different for you.
- Nathan
On Thu, May 2, 2013 at 7:03 PM, MORREALE Jean Roc
<jr.morreale at enoreth.net>wrote:
> Hi Werner,
> Thank for the answer, I already tried git reset but got stuck on that :
> $ git reset --hard upstream/master
> fatal: ambiguous argument 'upstream/master': unknown revision or path not
> in the working tree.
> Use '--' to separate paths from revisions, like this:
> 'git <command> [<revision>...] -- [<file>...]'
> But applying the command 'git remote update' before it did the trick !
> I didn't knew this command, should it be used instead of fetch/pull
> upstream ?
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130502/a9a32f74/attachment.html>
