[Qgis-developer] Git help needed
MORREALE Jean Roc jr.morreale at enoreth.net
Thu May 2 06:04:13 PDT 2013
thx for these tips nathan !
Le 02/05/2013 11:30, Nathan Woodrow a écrit :
> Generally you should work and push branches to github and issue pull
> requests on those.  It will make it easier to keep your pending commits
> and changes out of your master branch so you can update it like normal
> git checkout -b mywork
> do you stuff..
> git commit -m "My changes"
> git push origin mywork
> Pull request on mywork branch.
> You can then keep master in line by doing:
> git checkout master
> git pull --rebase upstream/master
> upstream == QGIS github repo, might be different for you.
> - Nathan
> On Thu, May 2, 2013 at 7:03 PM, MORREALE Jean Roc
> <jr.morreale at enoreth.net <mailto:jr.morreale at enoreth.net>> wrote:
>     Hi Werner,
>     Thank for the answer, I already tried git reset but got stuck on that :
>     $ git reset --hard upstream/master
>     fatal: ambiguous argument 'upstream/master': unknown revision or
>     path not in the working tree.
>     Use '--' to separate paths from revisions, like this:
>     'git <command> [<revision>...] -- [<file>...]'
>     But applying the command 'git remote update' before it did the trick !
>     I didn't knew this command, should it be used instead of fetch/pull
>     upstream ?
