[Qgis-developer] Git help needed
Werner Macho werner.macho at gmail.com
Thu May 2 05:48:20 PDT 2013
Hi JR
It all depends how YOU called your "upstream" .. your fork on github after
cloning is always called "origin" ..
The rest depends which repository you cloned and which one is the remote
attached ..
You can take a look at:
http://quantumofgis.blogspot.co.at/
there i explained "my" workflow for translations ..
I will extend that with a GRASS entry in the next few weeks too - and
afterwards I'll move to branching and merging explanations .. :)
git is not THAT difficult once you are used to it ..
regards
Werner
On Thu, May 2, 2013 at 11:03 AM, MORREALE Jean Roc
<jr.morreale at enoreth.net>wrote:
> Hi Werner,
> Thank for the answer, I already tried git reset but got stuck on that :
> $ git reset --hard upstream/master
> fatal: ambiguous argument 'upstream/master': unknown revision or path not
> in the working tree.
> Use '--' to separate paths from revisions, like this:
> 'git <command> [<revision>...] -- [<file>...]'
> But applying the command 'git remote update' before it did the trick !
> I didn't knew this command, should it be used instead of fetch/pull
> upstream ?
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130502/96a3f2ae/attachment.html>
