[Qgis-developer] Histograms huge
Paolo Cavallini cavallini at faunalia.it
Thu May 2 10:21:05 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 01/05/2013 11:24, Matthias Kuhn ha scritto:
>> * the fixed size of the pies is greyed out, and I do not see how to
>> change it
> Qt designer erased the slot signals when I changed from toolboxes to
> tabs. Will be fixed upon next commit.
OK, now fine, thanks.
>> * wouoldn't it be better to autofill the Max Value field for size scaling?
> Not sure. A user might want to have a more natural mapping of attributes
> / value (e.g. 1cm /100 people) instead of using a maximum value. This
> should rather be a help than a default value IMO.
Agreed, but having a prefilled field ensures that an unexperienced user can always
get a result, and refine it later. I still vote for the autofill.
By default, the attribute used should be the first one selected, or even better the
one with the highest value.
With these two changes, the user is guaranteed to get his graph plotted and visible,
otherwise some frustration may occur.
> Which attribute is selected does not matter here at all. It's really
> just a helper to get a reasonable default value in this context.
> I gave it another try.
A few minor notes:
* It would be nice that on reopening the user will find the last used tab, instead of
going back to the first one.
* The default for scale dependent visibility should match those on the General tab
rather than being -1.
Overall, a good improvement, thanks.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlGCoIEACgkQ/NedwLUzIr5MeACbBPxpXxwooBjtjEw1ueJFGEF/
728AnA0QButij0Qp9YrDaUOLzqyC7foE
=jFB6
-----END PGP SIGNATURE-----
