[Qgis-developer] many SVG symbols disappeared
Tim Sutton
lists at linfiniti.com
Mon May 6 13:55:54 PDT 2013
Hi
On Mon, May 6, 2013 at 2:31 PM, Olivier Dalang <olivier.dalang at gmail.com> wrote:
> I was asking that question on this thread :
> http://osgeo-org.1560.x6.nabble.com/Ideas-on-the-SVG-symbols-library-td5040508.html#a5046486
> Maybe I didn't emphasize enough on the deletion of symbols...
> IMO, the most elegant solution is to keep only the good-looking symbols so
> we provide a simple and consistent library, and then to provide a link on
> the website to download the unmodified 1.8 symbol library in case one needs
> to keep full backwards compatibility (it's quite easy to install : you just
> have to replace the SVG folder in your installation folder).
> The whole pull request already breaks backwards compatibility with all other
> symbols, since by removing their background, the may become unreadable on
> most of the maps...
> So if the priority is the keep old projects looking the same rather than
> having a clean and consistent library, the best is not to change the svg
> library at all.
> (just as an illustration, do you really think it's pertinent to keep this in
> the library ? :
> https://www.dropbox.com/s/jj9e852r08w5ysp/north-arrow_10_with_map_layers.png
Yeah that ain't pretty...
Personally I like Oliver's patch and I think we should clean up house
for 2.0. Keeping compatibility is useful but most of my project files
from 1.8 are already broken to some degree and I would prefer we do
all the big changes in 2.0 and then become more conservative in
subsequent 2.x releases.
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
