[Qgis-developer] composer export fails for maps with label shadows
HAUBOURG regis.haubourg at eau-adour-garonne.fr
Tue May 7 05:28:28 PDT 2013
Well, I'm using 471dab1 revision from osgeo4w (probably Sunday night build). I had no message raised.
I will update my version and make more exhaustive tests reports.
Cheers,
-----Message d'origine-----
De : Nyall Dawson [mailto:nyall.dawson at gmail.com]
Envoyé : mardi 7 mai 2013 14:19
À : HAUBOURG
Cc : qgis-developer
Objet : Re: [Qgis-developer] composer export fails for maps with label shadows
On 7 May 2013 17:40, Régis Haubourg <regis.haubourg at eau-adour-garonne.fr> wrote:
> Hi, This morning I tried to export in pdf some multimaps composers.
> I encounter an error - not crashing qgis, but leaving composer blank -
> on maps using new dropshadows for labels. %Maybe it's related to
> blending or only shadows. I switched back to buffer, and it works OK, even A0.
> Anyone confirms?
Can you give me a few more details about this? Do you get an error message, or just the missing elements in the pdf file? A day or so ago I added a warning message when pdf exporting a composer view with blend modes to prompt you to export as raster, did you get this warning when exporting?
Nyall
