[Qgis-developer] Postgres Audit Trigger plugin: beta-tester & feedback
Denis Rouzaud denis.rouzaud at gmail.com
Tue May 7 05:20:34 PDT 2013
Hi all,
As some of you know, I have created a plugin to do rollbacks on postgres
layers using the Postgres Audit Trigger 91 plus [0].
The plugin is called Postgres 91 plus auditor is made for QGIS 1.9+ and
is now flagged as experimental.
I wrote a short howto [1].
If some of you are ok to test the plugin (maybe not on production data!)
and to give me some feedback on the plugin,  I would be very pleased!
Thanks a lot,
Denis
[0] http://wiki.postgresql.org/wiki/Audit_trigger_91plus
[1] http://3nids.github.io/postgres91plusauditor/
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130507/99c3906a/attachment.html>
